close
1 EWANAPI Descriptions / Examples of DMS Calls
2 Table of Contents
3 Introduction
3.1 History
3.2 Files
3.3 Interface expansion
3.4 Direct return codes of EWANAPI
4 Direct access to EWA download area
4.0.1 Objective
4.0.2 Parameters
5 WIS call interface
5.1 Determination of damage code
5.1.1 Objective
5.1.2 Parameters
5.1.3 Boundary conditions
5.1.4 Output
5.1.5 Example
5.2 Document display
5.2.1 Objective
5.2.2 Parameters
5.2.3 Boundary conditions
5.2.4 Output
5.2.5 Examples
6 ASRA net call interface
6.1 Objective
6.2 Parameters
6.3 Boundary conditions
6.4 Output
6.5 Examples
7 ASSYST call interface
7.1 Without background call
7.1.1 Objective
7.1.2 Parameters
7.1.3 Boundary conditions
7.1.4 Output
7.1.5 Examples
7.2 WIS ASSYST Call
7.2.1 Objective
7.2.2 Parameters
7.2.3 Output
7.2.4 Boundary conditions
7.2.5 Examples
7.3 WIS Maintenance Service System (MSS) Call
7.3.1 Objective
7.3.2 Parameters
7.3.3 Output
7.3.4 Examples
8 EPC call interface
8.1 EPC Navigate Call
8.1.1 Objective
8.1.2 Parameters
8.2 Examples
8.3 EPC Search Part Call
8.3.1 Objective
8.3.2 Parameters
8.4 Examples
2 Table of Contents
2 Table of Contents
3 Introduction
3.1 History
3.2 Files
4.0.1 Objective
4.0.2 Parameters
5.1.1 Objective
5.1.2 Parameters
5.1.4 Output
5.1.5 Example
5.2.1 Objective
5.2.2 Parameters
5.2.4 Output
5.2.5 Examples
6.1 Objective
6.2 Parameters
6.4 Output
6.5 Examples
7.1.1 Objective
7.1.2 Parameters
7.1.4 Output
7.1.5 Examples
7.2 WIS ASSYST Call
7.2.1 Objective
7.2.2 Parameters
7.2.3 Output
7.2.5 Examples
7.3.1 Objective
7.3.2 Parameters
7.3.3 Output
7.3.4 Examples
8.1.1 Objective
8.1.2 Parameters
8.2 Examples
8.3.1 Objective
8.3.2 Parameters
8.4 Examples
3 Introduction
3.1 History
This document describes the call interface in the EWA project. Here, the existing "WISAPI" interface for the "classic" WIS product was used as a basis to define an interface allowing the "WIS/ASRA/EPC" applications to be called up in a way that is very compatible to that of the previous concepts in the "classic" world. Even more it has been extended subsequently and now allows also some control over the EPC client.
Significant stages of development were:
This document focuses on merging the following two files:
The technical details have been removed so that the document basically can be used as an external call reference.
3.2 Files
Standard Installations ("Local" and "Central"):
The following files comprise the installation of the call interface in a standard environment ("local" or "central"):
File
Description
ewanapi.exe
Call interface program
ewanapi.ini
Configuration file
hpwin32.dll
System expansion for Win32 functions
wisapi.exe
Program identical to "ewanapi.exe", for backwards compatibility to existing calls
ewanapi.jar
Contains the classes for the external EWANAPI interface. This JAR file is needed by EWANAPI to run specific operational steps.
Developers who want to bundle EWANAPI code in their own applications need the JAR file during development and the JAR file plus the DLL in the runtime environment.
Standalone Installation:
When installed by the WIS standalone installer (i.e. in the STAR DIAGNOSIS environment) following files comprise the installation, but the call interface on the command line is exactly the same:
File
Description
ewanapi.exe
Call interface launcher program
ewanapi.ini
Configuration file
hpwin32.dll
wisapi.exe
ewanapi.jar
JAR file containing the application code
ewanapi.config
Config file for the launcher indicating to where the Java Runtime is installed. This is needed as the standalone installation has its own private JRE.
wisapi.config
Same as above for the WISAPI.exe launcher program
External Java EWANAPI Interface:
System integrators who want to make use of a more tight EWA integration via EWANAPI may want to make use of the EWANAPI Java API which is provided within the file ewanapi.jar on the official delivery DVD of EWA. The file can be found in the directory[DVD]:\ewa\Apps_sd\ewanapi_sd\application. Additional technical developer documentation can be requested from the EWA product management team.
In general, the call interface had to be expanded to include the following parameters - all of them are optional, but typically the credential information might be needed to authenticate against a given EWA application server:
Parameters
Description
Mandatory/
optional
Example
Hint
-application
Type of application to be started. Parameter can be used to directly open the EWA download area, too.
Permitted values:
WIS-Net
(for WIS)
EPC-Net
(for EPC)
DOWNLOAD
(for EWA download area)
Optional
-application EPC-Net
If not specified, the "WIS-Net" value is internally used for backwards compatibility.
Thus for calls to the WIS application this parameter can silently be omitted
-userid
User name that must be presented at the EWA AccessGateway.
Optional
-userid stollms
If this is not specified, a login is attempted without a UserID and usually results in failure.
But as soon as a client application is already up and running, this parameter can be omitted.
User credentials (userid, password and domain information) can be omitted in case of a background call (see below for those calls) or if you run your environment with Single SignOn (SSO) enabled. In the latter case EWANAPI will pass through the credentials of the currently logged on user.
-userdomain
Windows domain information (if used)
Optional
-userdomain localworkshop
Can be excluded if no domain information is used.
-userpwd
User password
Optional
-userpwd password
Without this information, login to the device usually will fail unless SSO is enabled or a background call will be issued.
You can also provide an already crypted password here. This might be helpful if you care about sending the password over an unsecured line.
The password (if crypted) must be SHA-1 crypted to be recognized.
In case of an SSO enabled environment EWANAPI will pass through the credentials of the currently logged on user.
-smcookievalue
Value of a Siteminder Cookie (if available).Optional
-smcookievalue "EHJFGEUWLSHDTWKL/&HF12"
This cookie value will typically only be availabe from Siteminder protected infrastructure clients. This is not a value a typical user will know about.
This value can be used to authenticate at an EWA server which is Siteminder protected. Then this cookie can be sent without further user information.
-smcookiename
Value of a Siteminder Cookie Name (if available).Optional
-smcookiename EWA_SMSESSION
There is a default name "SMSESSION" which by default is the name of a cookie in a standard installation of Siteminder. If the caller knows that the target system runs a Siteminder with a different name for the cookie, this can be overridden here.
Alternatively it can be set persistantly inside the EWANAPI.ini file.
-triggername
Communication channel on which a DMS system can specify if it wants to be actively notified of a completed call.
Optional
-triggername kerridge_pipe_15
This may currently not yet be supported by the client applications WIS and EPC
-debug
Writes additional information to the console
Optional
-debug
-debug C:\EWANAPI.log
You may optionally specifiy a log file into which the debug information will be written.
-locale
Specifies the locale to be used when starting the application and creating a session on the application server
Optional
-locale de_DE
If not specified EWANAPI automatically sends the current locale settings of the client to the EWA server.
-processid
The optional processID is a random number in the form of a UUID formatted as a string. It is a unique instance key used for the Data Exchange Service (SAR-WebParts) integration allowing a running instance [of EPC or WIS] to be uniquely identified from all instances [of WIS or EPC] running on computers anywhere in the world at one time.
Optional
-processid f47ac10b-58cc-4372-a567-0e02b2c3d479
If specified then EPC and WIS save Shopping Lists and Job Order via the Data Exchange Service.
-server
Specifies the URL to the EWA-server. It has to be the host-name or ip-address without port or protocol. If specified, this URL will be used to connect to the server, instead of the one specified in EWANAPI.ini or ewanapi.cookie. If no previous configuration exists, the ewanapi.cookie will be created.
Optional
-server 16.58.251.4
-port
Specifies the port of the EWA-server. If specified, this URL will be used to connect to the server, instead of the one specified in EWANAPI.ini or ewanapi.cookie. This parameter will only be used if the -server-parameter has been specified. If no previous configuration exists, the ewanapi.cookie will be created.
Optional
-port 9001
If this parameter is not specified the default value is used: 9000.
-https
Specifies the protocol of the EWA-server. If specified, this URL will be used to connect to the server, instead of the one specified in EWANAPI.ini or ewanapi.cookie. This parameter will only be used if the -server-parameter has been specified. If no previous configuration exists, the ewanapi.cookie will be created.
Optional
-https true
If this parameter is not specified the default value is used: false.
-prefercookie
Specifies whether the host-settings given by the parameters (-server) or by the cookie should be preferred.
This only has an effect, if the paramter -server has been specified.
If the server- and the prefercookie-parameter have been set, the host-settings defined in the EWAnapi-Cookie will be used for connection (if available).
If the server-parameter has been set without prefercookie, the server-parameter will be used for connection.
Optional
-prefercookie
If this parameter is not set, the server-parameter will be preferred (if specified).
These parameters are always specified in the following calls.
EWANAPI forwards the business request to the correct client application which is responsible to evaluate the call and react correctly. In case of errors or incomplete or even wrong commandlines the clients write error codes into an error file - if an error file has been specified.
But there are cases when EWANAPI cannot even handle the call. In this case it returns specific error codes to the calling application. In a command line you may react on this reading the Windows %errorlevel% command line variable. Within application code the process will return the given code. Following error codes exist:
Error codeDescription
-2Parameter parsing error. Invalid commandline specified.
Background info: the EWANAPI launcher performs some basic command line consistency checks.
Note: Typically this shall not happen within system integration as the end user will have no chance to work around this issue.
1000Configfile could not be found.
1001Incorrect/missing value(s) in config file.
1002Connection to server failed. This can happen if the connection to the AccessGateway is broken/cannot be established.
1003Communication error. Client cannot be found/started. This can happen if the client does not answer on the communication channel, or i.e. Java Webstart could not be found to start the application.
1004Authentication error. AccessGateway denied the access.
1005WebStart or Application Start not possible.
1006Named access authorization already in use. No new access authorization could be allocated.
1007Account has (temporary) been locked. You may try again later.
1008A password change is due for the given account.
(The user may try again after having changed his password).
1009Account has been disabled.
any other codeError codes provided by a server contacted by EWANAPI.exe which EWANAPI.exe does not know will simply be returned to the command line as error code.
I.e. a HTTP server errorcode like 599 from an application server contacted by EWANAPI.exe would be unknown to EWANAPI and returned as error code 599.
4.0.1 Objective
The EWA download area can be directly opened from a command line.
4.0.2 Parameters
The syntax for accessing the EWA download area is as follows:
ewanapi -application DOWNLOAD  -userid <your_userid> -userpwd NEWS:<EWA-token>
       [-server <server-url>] [-port <server-port>]
Parameter details:
Parameter
Description
Mandatory/
Optional
Example
Notes
-userpwd NEWS:
Token generated by EWA TokenGenerator.
M
-userpwd NEWS:AQH+g4wLA-346345MD+NwQltdVg2duICFE-345tr+bXGfT7qLsAPKBFdxVy
5.1.1 Objective
The WIS damage code module can be directly called up from a command line. The code determined is written to a file.
5.1.2 Parameters
The syntax for calling up WIS to determine a damage code is as follows:
ewanapi[1] -S <filename>  -t <Model> | -V <VIN>  [-F <FGR>  [-f <FUG>]]
              [-damagedpart <damagedpart> [-damageid <damageid>] [-damagetype <damagetype>] [-repairtype <repairtype>]]
              [-err <filename>]
              -application WIS-Net
              -userpwd <your_passwd>
              -userdomain <your_domain>
The parameters in detail:
Parameters
Description
Mandatory/
Optional
Example
Notes
-S
File name for the return of the damage code determined
M
-S C:/tmp/ssl.txt
If WIS shall not store the resulting information into a file, a special value of [null] must be provided.
But the argument must always be given.
-t
Model type
(6-digit)
M
-t 202018
Either -t or -V must be provided.
-V
VIN (17 alphanumeric characters)M
-V WDB2102171A354643
-F
Function group
O
-F 10
-f
Function subgroup
O
-f  30
Can only be used in conjunction with function group.
-damageid
The id of a damage (as fragment of a damage code)O
-damageid 1
Can only be used in conjunction with "-damagedpart" option.
-damagedpart
A partnumber of a damaged part (as fragment of a damage code)O
-damagedpart 54148
-damagetype
The type of a damage (as fragment of a damage code)O
-damagetype 78
-repairtype
The repair type of a damage (as fragment of a damage code)O
-repairtype 7
-err
File name for returning the error code
O
-err C:/tmp/error.txt
If a path is not given, the folder from which the module is opened is used.
5.1.4 Output
If a complete damage code has been determined, then on Quit, this key is saved in the output file. In this way the last completely determined damage code is valid. The format of the file is as follows:
Damage_identification_designation_type_of_damage_type_of_repair
whereby the damage identification can have the value 0 (for original equipment fit) and 1 (for replacement part/replacement unit). The identification is a 5-digit code and describes the component (e.g. 05212: inner valve spring). The damage type is represented by a 2-digit code (e.g. 06: broken), the repair type by a one-digit code (e.g. 1: replace unit). All values are separated by a space. As soon as the Damage code 1 screen is left using the F8 button (End), the MB-WIS quits.
5.1.5 Example
  1. ewanapi -S C:\temp\key.txt -t 210035 -F 42 -f 30 -err C:\temp\error.txt -application WIS-Net -userid stollms -userpwd 478967895 -userdomain sampledomain
    The "Damage code 1" screen appears. The function group 42.30 (ABS) is preselected. Following selection of an image title, the "Determine damage code" button becomes activated. This takes the user to the "Damage code 2" screen, where - following the selection of the component, the type of damage, the damage identification and the type of repair - the damage code is displayed. At the same time the "Apply" button becomes activated; this button is used to select the damage code. After returning to "Damage code 1" using the "Back" button and quitting the application, the following entry is to be found in C:\temp\key.txt:
    0 03203 06 7
    i.e., the connecting rod bolt (03203) is broken (06). This is a replacement of original equipment (0), whereby repair using material (07) is necessary.
  2. ewanapi -S C:\temp\key.txt  -t 210  -F 42  -f 30 –err C:\temp\error.txt -application WIS-Net -userid stollms -userpwd 478967895 –userdomain sampledomain
    Error code 2 is output to the error file, as there is no 6-digit model designation available; as such, it is not possible to determine the damage code.
5.2.1 Objective
The specified document is displayed in (and optionally printed from) the WIS "Document display". It is also possible to prepare a document search, i.e. to open "Infothek 1" or "Infothek 2".
5.2.2 Parameters
The following calls are supported:
  1. ewanapi -D
       ((-t <type_model_designation> [-m <engine_model_designation>] [-a <major_assembly_model_designation_1>,..,<major_assembly_model_designation_n>])
     | ([-t  <type_model_designation>] -m <engine_model_designation> [-a <major_assembly_model_designation_1>,..,<major_assembly_model_designation_n>])
     | ([-t <type_model_designation>] [-m <engine_model_designation>] -a <major_assembly_model_designation_1> [,..,<major_assembly_model_designation_n>]))
        [-f <function_group_1>,..,<function_group_n>]
        [-i <info_type_1>,..,<info_type_n>]
        [-s <KD logic>] [-err <filename>] [-Z]
        [-p]
  2. ewanapi -D -V <VIN>
          [-s <KD_logic>]   [-err <filename>] [-Z]
          [-p]
  3. ewanapi -D <doc._no._1>[,..,<doc._no._n>] [-Z] [-T 1]
           [-p]
  4. ewanapi [–T <vehicle_type>] -t <type_model_designation> [-m <engine_model_designation> -a  <major_assembly_model_designation>]
          –A <WU_number> [-err <filename>]
          [-p]
  5. ewanapi -D -V <VIN> -A <WU_number> [-err <filename>]
            [-p]
If the document search only produces one hit, i.e. only one document is found, then this is displayed immediately.
The parameters for calls 1 to 3 (for variant 4 see below) in detail are:
Parameters
Format
Description
Mandatory/Optional
Example
Notes
-D
Alphanumeric
Document number
M
-D BB0040P012500A
As previously, only separated by comma (also repeated).
-V
Exactly 17 alphanumeric characters
Vehicle ident. number (with WMC)
M
Either "-V" has to be provided or "-t" (see below)
-t
6-digitsModel typeM
-t 202018
Either "-t" has to be provided or "-V" (see above)
-m
6 digits
Engine model designation
O
-m 611961
-a
6 digits
Major assembly model
O
-a 722613,768002
Multiple entries separated by commas possible.
-f
2 digits or 2 digits + point + 2 digits
Function group/subgroup
O
-f 00,20.10
Multiple identification separated by comma.
There is a special parameter "ALL" for all function groups.
-i
1 to 2 numeric characters
Info type code
O
-i 2,3,4
There is a special parameter "ALL" for all information types.
All supported information types will be listed in the separate table below.
-s
1 digit
Display logic for special cases
O
-s 0
Values = {0,1,2}
0 = Popup with question, "Display work instructions for special cases?"
1 = Only display work instructions for special cases.
2 = No display, no popup
This parameter is only activated on the input of a complete VIN (similar to Infothek-1).
-Z
Return option
O
-Z
On the input of –Z all screens are placed on the stack.
-T
1 character
Vehicle type code
O
-T 1
This parameter is only maintained for reasons of compatibility with old systems. It no longer has any functionality and is ignored when entered.
-p
 Print optionO
-p
If this option is given the retrieved documents will not only be shown in the result list, but also been printed to the default printer.
-err
Dependent on the operating system
O
Overview of supported infotype values:
Infotype value (integer)Information type nameComment
1Current topicsVirtual infotype. Aggregation of infotypes: 2, 3 and 4. Thus a call with parameter "-i 1" is equivalent to "-i 2,3,4"
2   Service informationsi
3   Introduction into Servicesn
4   Measures and instructionssm
5Work informationVirtual infotype. Aggregation of infotypes: 6,7,8,9,10,11
6   General safety informationah, as
7   Care and maintenanceap
8   Troubleshootingaf
9   Diagnosisad
10   Testing/repair workar
11   Retrofits/conversionsan, az
12Basic knowledgeVirtual infotype. Aggregation of infotypes: 13, 14
13   Functions, config.gf
14   Operating instructions
15Basic dataVirtual infotype. Aggregation of infotypes: 16 ... 27
16   Test/adjustment valuesbe
17   Tightening torquesba
18   Filling capacitiesbf
19   Specs for Op. Fluidsbb
20   Repair materialsbr
21   Technical changesbt
22   Circuit diagramsVirtual infotype. Aggregation of infotypes: 23, 24, 25
23      Electricpe
24      Hydraulicph
25      Pneumaticpp
26   Toolsws, wh, wf
27   Workshop equipmentwe
28OrganizationVirtual infotype. Aggregation of infotypes: 29, 30, 31, 32, 33
29   Forms, certificatesof
30   Envir. protection cond.
31   Hazardous waste disposalos
32   Warranty manual
33   Administrationov
Parameters for variant 4 (document search with WU value) in detail:
Parameters
Description
Mandatory/Optional
Example
Notes
-T
Vehicle type code
M
-T 1
-t
Model type
(6-digit)
M
-t 202018
-m
O
-m 102921
-a
O
-a 760700
-A
Operation number
M
-A 421050
-p
Print indicatorO
-p
Not only display the documents, but also print them to the default printer.
-err
O
Parameters for variant 5 (document search with WU value and VIN) in detail:
Parameters
Description
Mandatory/Optional
Example
Notes
-V
M
-A
Operation number
M
-A 421050
-Z
O
-Z
Return option
-p
Print indicatorO
-p
-err
O
  1. The two parameters "-D" are used for starting the document search. If there are no other parameters after this but another character, then this is interpreted as a document number.
  2. The number of parameters after the options "-f" and "-I" is limited to 20.
  3. Only 6-digit models are accepted.
  4. The parameters for the call are to be arranged according to the various possibilities. A mixture between a document search with document number, or, e.g., with function groups and info. types, or with a WU search is not allowed. It is currently known that WIS may not generate an error file in such cases.
  5. The parameter "-s" is, similar to WIS (Infothek-1), only activated in the case of the complete entry of the VIN. Otherwise the parameter has no effect.
  6. In the case of lists in parameters (e.g. several information types, function groups or documents), it is not allowed to use spaces (e.g. –i 1,2); alternately the entire character string must be placed in quotation marks (e.g. –i "1, 2").
  7. In call 3 the parameter –T 1 can also be set; however in this case this parameter is ignored.
  8. In call 5, no info. types or function groups may be entered.
5.2.4 Output
The return values for these calls are:
5.2.5 Examples
  1. ewanapi –D si0000p0005c  -application WIS-Net -userid stollms -userpwd 478967895 –userdomain sampledomain
    The document with number Si00.00-P-005C is displayed.
  2. ewanapi –D si0000p0005c -p -application WIS-Net -userid stollms -userpwd 478967895 –userdomain sampledomain
    The document with number Si00.00-P-005C is displayed and printed to the default printer.
  3. ewanapi –T 1 –t 210217 –A 421050 -application WIS-Net -userid stollms -userpwd 478967895 –userdomain sampledomain
    A selection of documents with operation number 42-1050 that correspond to model designation 210.217 is shown.
  4. ewanapi -D -V WDB2020181L0000 -A 421050 -err C:\err.txt -application WIS-Net -userid stollms -userpwd 478967895 –userdomain sampledomain
    A selection of documents with operation number 42-1050 that correspond to VIN WDB2020181L0000 is shown. Error messages are saved to the C:\err.txt file.
6.1 Objective
Activation of the ASRA retrieval system.
6.2 Parameters
Numerous combinations of parameters are supported:
ewanapi[3] –ASRA  [-Background]  [-V <VIN>] [–WMC <WMC>]
               [  [[-T <type_model_designation>]  [-M <engine_model_designation>] [-L <steering/plant>]]  [-P <production_number>]  ]
               [–A <operation_position_number>[,operation_position_number,...]] [-AN order_number] ]  [-D <filename>] [-err <error_file>]
Parameters
Description
Mandatory/Optional
Example
Notes
-ASRA
Flag for activating the ASRA retrieval system
M
-Background
Flag for activating execution in the background
O
Does not allocate any access authorization within EWA, but starts WIS as a background process which terminates directly after this action.
The call is made user unspecific: no user credentials have to be provided for this call.
Even if another WIS client was up and running already this would not be used for this call.
-WMC
World Manufacturer Code
O
-WMC WDB
Due to the changed WMC handling in ASRA-ES, it is not necessary to input the WMC. If this parameter is nevertheless input, a check is also made against the specified model.
-V
Vehicle Identification Number.O
Exactly 17 alphanumeric characters including the WMC.
Either model type "-T" or VIN "-V" are allowed at once.
WMC is not needed in this case.
-T
Model type
(6-digit)
O
-T 202018
-M
Engine code
(6-digit)
O
-M 111920
The optional engine designation may help filtering information within ASRA.
-L
Steering/plant
O
-L 1a
Can only be used in conjunction with model type.
-P
Production progress number
(6-digit)
O
-P 123456
Can only be used in conjunction with model type and steering/plant.
-A
Operation item number(s)
O
-A 421050,421060
Only useful in combination with a fully specified vehicle.
-AN
Order number
O
-AN 12xx34
Only useful in conjunction with operation item number.
-D
File name for the return of the list of operation items
O
-D C:/tmp/liste.txt
-err
O
6.4 Output
The error codes for these calls are:
Error DescriptionError Code
No error0
No access authorization or missing connection to the access authorization manager-1
Invalid WMC (does not exist or digit # < 3)-101
Vehicle was not found-102
Invalid model (digit # < 3)-103
Invalid entry of steering/plant (digit # <> 2)-104
Invalid production number (digit # <> 6)-105
Invalid engine (digit# <>6, engine does not match to model)-106
Invalid operation item (digit # <> 6)-109
Operation item was not found-110
Inconsistent vehicle specification-111
No access authorization for ASRA-112
Invalid output file-114
Background call with ambiguous model type-115
The error field in the job order file can be filled with the following values:
No changes00
Vehicle changed01
Operation items changed02
6.5 Examples
  1. ewanapi -ASRA -T 210017 -L 1A -P 123456 -A 421050 -D C:\jobtest.txt -err C:\errtest.txt -application WIS-Net -userid stollms -userpwd 478967895 -userdomain sampledomain
    After the call, folder C:\ contains a job order file "jobtest.txt" and a file "errtest.txt", which also contains in addition to the call log, the return value (in this case: 0). If the ‘-D’ parameter is not given, the user is prompted for the job order name.
  2. ewanapi -ASRA -T 202018 -M 111920 -L 1A -P 123456 -A 421050 -D C:\jobtest.txt -err C:\errtest.txt -application WIS-Net -userid stollms -userpwd 478967895 -userdomain sampledomain
  3. ewanapi -ASRA -Background -T 210017 -L 1A -P 123456 -A 421050 -D C:\jobtest.txt -err C:\errtest.txt
    The same case as in 2., but there is no interaction with the user (background call).
  4. ewanapi -ASRA -T 202018 -A 00 -application WIS-Net -userid stollms -userpwd 478967895 -userdomain sampledomain
    The "ASRA vehicle determination" screen appears with specified vehicle context. For the design group "00" (service) is preselected and the design group table of contents indicates the appropriate subgroups.
  5. ewanapi -ASRA -T 21002 -AN 1000ab -D C:\jobtest.txt -application WIS-Net -userid stollms -userpwd 478967895 -userdomain sampledomain
    A popup screen appears for selecting a model designation. Caution: The order number is not applied in the context, because the vehicle was not completely specified in the call. After <Back>, no job order file is written. If operation items are subsequently selected, a job order with the name given is written when the application quits.
  6. (Invalidate access authorization)
    ewanapi -ASRA -T 202018 -D jobtest.txt -err errtest.txt -application WIS-Net -userid stollms -userpwd 478967895 -userdomain sampledomain
    Error code "-1" is generated.
  7. ewanapi -ASRA -WMC abc -D jobtest.txt -err errtest.txt -application WIS-Net -userid stollms -userpwd 478967895 -userdomain sampledomain
    Error code "-101" is generated.
  8. ewanapi -ASRA -T 123456 -D jobtest.txt -err errtest.txt -application WIS-Net -userid stollms -userpwd 478967895 -userdomain sampledomain
    Error code "-102" is generated.
  9. ewanapi -ASRA -T 12 -D jobtest.txt -err errtest.txt -application WIS-Net -userid stollms -userpwd 478967895 -userdomain sampledomain
    Error code "-103" is generated.
  10. ewanapi -ASRA -T 202018 -L 1 -D jobtest.txt -err errtest.txt -application WIS-Net -userid stollms -userpwd 478967895 -userdomain sampledomain
    Error code "-104" is generated.
  11. ewanapi -ASRA -T 202018 -L 1a -P 12 -D jobtest.txt -err errtest.txt -application WIS-Net -userid stollms -userpwd 478967895 -userdomain sampledomain
    Error code "-105" is generated.
  12. ewanapi -ASRA -T 202018 -L 1a -P 123456 -A 00100 -D jobtest.txt -err errtest.txt -application WIS-Net -userid stollms -userpwd 478967895 -userdomain sampledomain
    Error code "-109" is generated.
  13. ewanapi -ASRA -T 202018 -L 1a -P 123456 -A 001055 -D jobtest.txt -err errtest.txt -application WIS-Net -userid stollms -userpwd 478967895 -userdomain sampledomain
    Error code "-110" is generated.
  14. ewanapi -ASRA -WMC WDB -P 123456 -D jobtest.txt -err errtest.txt -application WIS-Net -userid stollms -userpwd 478967895 -userdomain sampledomain
    Error code "-111" is generated.
  15. (Activate "WIS without ASRA" access authorization)
    ewanapi -ASRA -D jobtest.txt -err errtest.txt -application WIS-Net -userid stollms -userpwd 478967895 -userdomain sampledomain
    Error code "-112" is generated.
  16. ewanapi -ASRA -Background -T 220 -D jobtest.txt -err errtest.txt
    Error code "-115" is generated.
  17. ewanapi -ASRA -T 210017 -M 123456 -L 1A -P 123456 -A 421050 -D C:\jobtest.txt -err C:\errtest.txt -application WIS-Net -userid stollms -userpwd 478967895 -userdomain sampledomain
    Error code "-106" is generated.
  18. ewanapi -ASRA -T 210017 -M 123 -L 1A -P 123456 -A 421050 -D C:\jobtest.txt -err C:\errtest.txt -application WIS-Net -userid stollms -userpwd 478967895 -userdomain sampledomain
7.1.1 Objective
Activation of the ASSYST retrieval system.
7.1.2 Parameters
  1. ewanapi[4] -ASSYST -V <FIN> [-s <service_code>] [-w <workshop_code>]
                  [-K <customer_name>] [-A <order_number>]
                  ( [-k <current_km_reading>] | [-M <current_mileage_reading] )
                  [-r <correctness_service_supervisor>] [-f <completion_date>]
                  [-v <type_of_oil/viscosity>] [-d <dialog_acceptance>]
                  [-h <notes>] [-rt <remaining_time>] [-rd <remaining_distance>]
                  [-D <job_order_filename>] [-err <filename>]
                  [-ssc <service_scope >]
                  -annahmeblatt
  2. ewanapi[5]  -ASSYST -t <type_model_designation> -m <engine_model_designation> [-s <service_code>] [-w <workshop_code>]
                  [-S <special_equipment_code>] [-K <customer_name>] [-A <order_number>]
                  -annahmeblatt
The parameters for call a. in detail:
Parameters
Format
Description
Mandatory/Optional
Example
Notes
-V
M
-s
2 alphanumeric characters
Service code
O
-s A+
-w
1 to 22 alphanumeric characters
Workshop code
O
-w 24E
-K
1 to 32 alphanumeric characters
Customer name
O
-K "John Smith"
-A
1 to 15 alphanumeric characters
Order number
O
-A 12345
-k
1 to 7 numeric characters
Current km reading
O
-k 25000
Not together with the current mileage reading (see also boundary conditions).
-M
Current mileage reading
O
-M 12000
Not together with the current km reading (see also boundary conditions).
-r
Correctness by service supervisor
O
-r "John Smith"
-f
10 alphanumeric characters
Completion date
O
-f  01.12.2001
Format of the date can be transferred country-specific.
-v
Type of oil/viscosity
O
-v "SAE 15/40"
-d
1 numeric character
Dialog acceptance completed (yes/no)
O
-d 1
1 = Yes
0 = No
-h
1 to 300 alphanumeric characters
Note/explanation
O
-h "This is a note"
-rt
numeric value
The remaining time in days until or past ideal service time.
O
-rt 5
The value can also be negative to specify that the service-date has already passed.
-rd
numeric value
The remaining distance (in km or miles) until or past ideal service time.
O
-rd 2200
The value can also be negative to specify that the service-time has already passed.
-D
O
-D C:/tmp/liste.txt
-err
 the error code
O
-ssc
1 character
Service scope to be set
O
-ssa A
Values = {A, B}
If the option -ssc has been specified, one of the possible parameter values, A or B, has to be specified also
-annahmeblatt
No further parameters
Print annahmeblatt
O
-annahmeblatt
If the option -annahmeblatt has been specified, the Annahmeblatt is printed along with the Serviceblattes
The parameters for call b. in detail:
Parameters
Format
Description
Mandatory/Optional
Example
Notes
-t
Exactly 6 numeric characters
Model type
M
-t 202018
-m
M
-m 102921
-s
Service code
O
-s A+
-w
Workshop code
O
-w 24E
-S
1 to 4 alphanumeric characters
SA code
O
-S 850a
Is only used to determine the model year, i.e. in the case of this example, the entry has no effect (example 850a describes air conditioner for USA).
-K
Customer name
O
-K "John Smith"
-A
Order number
O
-A 12345
-k
Current km reading
O
-k 25000
-M
O
-M 12000
-r
O
-r "John Smith"
-f
Completion date
O
-f  01.12.2001
-v
O
-v "SAE 15/40"
-d
1 numeric character
O
-d 1
1 = Yes
0 = No
-h
Note/explanation
O
-h "This is a note"
-rt
numeric value
O
-rt 5
-rd
numeric value
O
-rd 2200
-D
O
-D C:/tmp/liste.txt
-err
 the error code
O
-ssc
1 character
O
-ssc A
Values = {A, B}
-annahmeblatt
Print annahmeblatt
O
-annahmeblatt
7.1.4 Output
No error0
Invalid call parameters-2
Vehicle could not be found in ASRA-102
Not all work positions could be found-203
7.1.5 Examples
  1. ewanapi -ASSYST -t 210020 -m 123456 -application WIS-Net -userid stollms -userpwd 478967895 -userdomain sampledomain
    The "Infothek 1" screen appears with an empty engine model designation table.
  2. ewanapi -ASSYST -t 211004 -m 646951 -application WIS-Net -userid stollms -userpwd 478967895 -userdomain sampledomain
    The "ASSYST" screen appears with preselected "With service processor".
  3. ewanapi -ASSYST -t 211004 -m 646951 -k 30000 -w 4g3p -application WIS-Net -userid stollms -userpwd 478967895 -userdomain sampledomain
    The "ASSYST" screen appears with completed "Current km reading" and "Workshop code" fields. The "Next" button is activated.
  4. ewanapi –application WIS-net –ASSYST –debug –userid stollms -userpwd 478967895 -ssc A
    The "ASSYST" screen appears with selected service scope A
7.2 WIS ASSYST Call
7.2.1 Objective
Activation of the service retrieval system in the background. The service sheet is printed automatically using the default printer in the MS Windows operating system. In addition, the job order file is written automatically.
It is to be noted that the background call is only to be used for vehicles with ASSYST-PLUS (service processor with workshop code). For this reason the workshop code is also a "mandatory" entry. The reason is: only with a workshop code can the additional work be determined without user interaction. In all other cases, as a rule, user interaction is unavoidable, and as a result a background call is then no longer meaningful.
7.2.2 Parameters
The following combinations of parameters are supported:
  1. ewanapi[6] -ASSYST -Background -V <VIN> [-s <service_code>] -w <workshop_code>
                 ( -k <current_km_reading> | -M <current_mileage_reading])
                  [-p] [-K <customer_name>] [-A <order_number>]
                  [-h <notes>] [-D <filename>] [-err <filename>]
  2. ewanapi[7] -ASSYST -Background -t <type_model_designation> -m <engine_model_designation> [-s <service_code>]  -w <workshop_code>
                  ( -k <current_km_level> | -M <current_mileage_level])
                  [-p] [-S <special_equipment_code>] [-K <customer_name>] [-A <order_number>]
Parameters
Format
Description
Mandatory/Optional
Example
Notes
-Background
Background execution
Does not allocate any access authorization within EWA, but starts WIS as a background process which terminates after this action.
This call is user unspecific which means that no user credentials have to be provided.
-V
M
-s
Service code
O
-s A+
-w
Workshop code
M
-w 24E
-p
Print service sheet
O
-p
If parameter given, then the service sheet is printed out on the default printer.
-K
Customer name
O
-K "John Smith"
-A
Order number
O
-A 12345
-k
Current km reading
M
-k 25000
-M
M
-M 12000
-r
O
-r "John Smith"
-f
Completion date
O
-f  01.12.2001
-v
O
-v "SAE 15/40"
-d
1 numeric character
O
-d 1
1 = Yes
0 = No
-h
Note/explanation
O
-h "This is a note"
-D
O
-D C:/tmp/liste.txt
-err
 the error code
O
-ssc
1 character
O
-ssa A
Values = {A, B}
Parameters
Format
Description
Mandatory/Optional
Example
Notes
-Background
-t
Model type
M
-t 202018
-m
M
-m 102921
-s
Service code
O
-s A+
-w
Workshop code
M
-w 24E
-p
Print service sheet
O
-p
-S
SA code
O
-S 850a
-K
Customer name
O
-K "John Smith"
-A
Order number
O
-A 12345
-k
Current km reading
M
-k 25000
-M
M
-M 12000
-r
O
-r "John Smith"
-f
Completion date
O
-f  01.12.2001
-v
O
-v "SAE 15/40"
-d
1 numeric character
O
-d 1
1 = Yes
0 = No
-h
Note/explanation
O
-h "This is a note"
-D
O
-D C:/tmp/liste.txt
-err
 the error code
O
-ssc
1 character
O
-ssa A
Values = {A, B}
7.2.3 Output
The error codes for these calls are (similar to ASRA background call):
No error0
Operation items have been removed due to type validity-203
The error code -2 signifies "invalid call parameter". For ASSYST this also includes model type designation or model type designation and engine model designation combinations that do not have "ASSYST PLUS". Thus, if e.g. a workshop code is entered and the model type does not have ASSYST-PLUS, WIS also quits with error code -2.
No changes00
Vehicle changed01
7.2.5 Examples
  1. ewanapi -ASSYST -Background -p -t 211004 -m 646951 -k 30000 -w 4g3p
    The dynamic service sheet is automatically printed out on the default printer and the job order file created as per the settings on the "System settings" screen.
7.3.1 Objective
Activation of the WIS Maintenance Module. An external caller may provide a vehicle context to start the module with by the parameters:
or
7.3.2 Parameters
  1. ewanapi[6] -MSS -V <VIN> [-err <filename>]
  2. ewanapi[7] -MSS -t <type_model_designation> [-m <engine_model_designation>] [-err <filename>]
Parameters
Format
Description
Mandatory/Optional
Example
Notes
-V
M
-err
 the error code
O
Parameters
Format
Description
Mandatory/Optional
Example
Notes
-t
Model type
M
-t 202018
-m
O
-m 102921
-err
 the error code
O
7.3.3 Output
No error0
Vehicle could not be found in MSS-102
No access authorization for MSS-112
7.3.4 Examples
  1. ewanapi -MSS -t 211004 -m 646951
    WIS will be startet, the vehicle context will be switched to type "211004". The selected engine will be "646951".
8.1.1 Objective
Activation of EPC and writing of a shopping list.
8.1.2 Parameters
The following number of parameter combinations is supported:
  1. ewanapi [-V <FIN>]
                  [-T <model code>]
                  -S <shoppinglist_file>
                  [-c]
                  [-partslist <partnumber[,partnumber...]>]
                  [-err <error_file>]
                  [-n <navigation path>]
Parameters
Description
Mandatory/Optional
Example
Notes
-V
Specification of the VIN incl. World Manufacturer Code
O
-V WDB2020281F333593
Either VIN or Model Code can be provided, not both of them
-T
Model codeO
-T 202028
-m
Engine number (6 digits)O
-m 104941
Can only be provided together with "-T" option
-S
File name for writing of the shopping list
M
–S C:\tmp\sl.txt
-c
Deletion of any existing shopping list is forced
O
-c
-partslist
One or more part numbers for parts that shall be added to the current shopping listO
-partslist A1089950520,N073379008100
-err
File name for the error file
O
C:\tmp\err.txt
-n
Navigation path to the message to be shown
O
-n navigation_path
If the option -n has been specified, the parameter navigation_path, has to be specified also
8.2 Examples
  1. ewanapi -V WDB2020281F333593 -S C:\tmp\sl.txt -c -err C:\tmp\err.txt -application EPC-Net -userid stollms -userpwd 478967895 -userdomain sampledomain
  2. ewanapi -V WDB2020281F333593 -S C:\tmp\sl.txt -partslist A1089950520,N073379008100 -application EPC-Net -err C:\tmp\err.txt -userid stollms -userpwd 478967895 -userdomain sampledomain
8.3.1 Objective
Activation of EPC and searching a given part.
8.3.2 Parameters
                  -pn <partnumber>
                  [-err <error_file>]
ParametersDescriptionMandatory/OptionalExampleNotes
-V
Specification of the VIN incl. World Manufacturer CodeM
-pn
File name for writing of the shopping listM
–pn A1089950520
-err
File name for the error fileO
C:\tmp\err.txt
8.4 Examples
  1. ewanapi –V WDB2020281F333593 -pn A1089950520 -application EPC-Net -userid stollms -userpwd 478967895 –userdomain sampledomain –err C:\tmp\err.txt
[1] The respective call applies for access to a running WIS; during this process the old context is deleted without a prompt and the open WIS reinitialized with the new parameters. This should on average contribute to significant time savings. If there is no open WIS application, it is started.
[2] This error code is only written to the optional error file (-err).
[3] The respective wisapi call applies for access to a running WIS; during this process the old context is deleted without a prompt and the open WIS reinitialized with the new parameters. This should on average contribute to a significant time savings.
[4] The respective ewanapi call applies for access to a running WIS; during this process the old context is deleted without a prompt and the open WIS reinitialized with the new parameters. This should on average contribute to a significant time savings.
[5] As footnote above!
[6] The respective wisapi call applies for access to a running WIS; during this process the old context is deleted without a prompt and the open WIS reinitialized with the new parameters. This should on average contribute to a significant time savings.
[7] As footnote above!
