close
1 EPC WIS/ASRA Operation Scenarios
1.1 Introduction
1.2 Basics
1.3 FAQ: Local vs. Central, Citrix, DMS
1.4 Central Operation Scenario – the recommended Solution
1.5 Central Operation Scenario with Citrix
1.6 Local Installation: EWA for one Workshop (incl. Subsidiaries)
1.7 Special local case: WIS/ASRA on Star Diagnosis Compact 4 and XENTRY Connect (XENTRY Kit)
1.8 Configuration Types
1.9 Individual Configuration Types
1.10 Summary
1.1 Introduction
Due to the flexible design of EWA (e.g. usage of the J2EE-architecture) the operational concept is very flexible and scalable. Depending on the required application setup, a suitable installation and operation scenario can be selected, and also be customized in various aspects:
1.2 Basics
EWA is a client/server application. This means:
 "Central" (Recommended)"Local" (Backup solution)
Network / InternetUsers use an existing network connection or an Internet connection to access EWA from the MPC or other central instances (ASP).The EWA server is located in a LAN in the dealer's environment - therefore no network connection from the workshop to the MPC or other central instances and no Internet connection is necessary.
Clients / GranularityThe EWA server runs at a central instance (e.g., at the MPC, for an entire market), serving a large number of widely distributed clients, usually many different workshops. The server is located centrally from the workshop point of view.The EWA server may run in a physically 'central' place, but only for a limited number of clients, i.e. the clients of one workshop (with subsidiaries). The server at the workshop is located locally from the workshop point of view.
Technological DemandsDue to the large number of clients the operation is more critical. Therefore this installation type usually requires somewhat "advanced" technology and server application setup/architecture like any other J2EE application used in that way.Server technology need not be that advanced; the 'out of the box' standard EWA configuration may be used.
Operation and SupportAn ASP or professional administrators takes care of operation, installation and updates.Local (workshop) administrators perform installation and updates, which are supported by automatic processes.
A third operation type of EWA exists that is not categorized as a client server application: Standalone.
Only WIS/ASRA is available as standalone application that can be installed on client systems, such as Star Diagnosis or XENTRY Connect.
This is supposed to be used in environments where no internet or network connection is possible. As this version is installed on a client machine, only one user can use the system and administrators have to maintain every single client machine instead of one central instalation.
Question: Is the EWA local scenario recommended in general?
Answer: Only if no central solution can be established, e.g. network connection to central servers not possible. In general a central solution should be the goal for the future.
Question: What is the suggestion for Dealers with insufficient network bandwidth?
Answer: Use the local installations or central installation with Citrix if the bandwidth for Citrix is sufficient and the Citrix approach in general is the goal.
Question: Is Citrix recommended in general?
Answer: Yes, but only if other goals also should be reached:
A Citrix setup only for EWA is not recommended – the expenses are too high!
Question: Are there differences in the functionality depending on the operation scenario?
Answer: In general No – exceptions are:
Question: Is the DMS-integration possible for each operation scenario and configuration?
Answer: In general Yes. Only in special cases some additional configuration efforts are necessary. Details will follow on request: if there is an urgent request for a special scenario which has to be proven please contact the EWA-team. Details for the most common DMS will follow.
Five default configuration types have been defined:
  1. Central/Big, non-EDC installation:
    Central installation for large number of users connected via Internet, Intranet, Extranet, VPN; custom application server and write database
  2. Central/Small:
    Central installation for limited number of users connected via Internet, Intranet, Extranet, VPN; modified standard EWA server installation (extended database)
  3. Local/Big:
    Workshop-central server for local LAN clients and workshop subsidiaries; standard EWA server installation, modifications for failure safety possible; no Internet connection
  4. Local/Medium-Small:
    Standard EWA installation on single PC or Workshop server (PC); no Internet connection
For details of hardware sizing take a look to Operations Manual
1.10 Summary
