             Clicking on one of the PR, MR or NT buttons in the toolbar at the
              top of the screen will bring up a menu which will allow you to specify
              what you are looking for in the documentation concerned.
            These menus have a common general structure.
            Above all, they allow you to define your search precisely by successive
              selections describing a Technical context. Thus, in the case
              of spare parts (PR), you need to select in sequence:
              -  the technical domain (left-hand column)
              - then the section (central column)
              - and finally the subsection (on the right).
            Figure 1: The PR access menu
              Les boutons de la ligne du bas ont les fonctions suivantes :
                To confirm the selection and access the information
                  (in certain cases, the program will prompt you additional information). |
                This button is active if the documentation in question has
                  already been consulted and enables you to return to the last
                  technical context consulted. |
                Allows you to access help on the documentation currently being
                  consulted.  |
                Closes the menu with no further action. |
